Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD Forum
FATAL ERROR: unhandled e06d7363h exception at fd92b3ddh CAD 2010
5 REPLIES 5
4857 Views, 5 Replies
Keep running into this error message when lauching CAD 2010 "FATAL ERROR: unhandled e06d7363h exception at fd92b3ddh CAD 2010" I've tried using the net framework uninstall tool but I am still getting running into the same problems.
5 REPLIES 5
pendean
What changed on your PC?
in reply to: pendean
Honestly,
I really don' t know what changed. This problem started happening over a week ago. Only thing I can think of is windows updates.
bryce.thelin
Hi Vinny,
Have you been able to send in some crash reports? If so, can you tell me a CER number? I can take a quick look and see if it tells us something.
Do you have the lastest update for AutoCAD 2010? Here is the download page:
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-2010-update-2...
You might have damaged settings files that are stopping AutoCAD from crashing. If you have your settings backed up, go ahead and try importing them. If you have AutoCAD 2010 running good on another computer, you could export settings from it and import those into yours. The export/import settings utilities are under Start > All Programs > Autodesk > AutoCAD 2010 > Migrate Custom Settings. Otherwise, to fully reset AutocAD 2010 to defaults, here are the steps:
http://knowledge.autodesk.com/article/Reinitiating-the-Secondary-Installer-for-AutoCAD
Bryce Thelin
AutoCAD Product Support
in reply to: bryce.thelin
please help me. to solve this problem.
thanks
AutoCAD Inside the Factory
