fatal error unhandled e0434f4dh exception at 7577845dh
Message 1 of 16
this error always pops up when i'm trying to copy (ctrl+c) some drawing and paste it to another file .dwg.  cause it total shutdown. no idea to troubleshoot. hope can get some help and advise here.
system info:
window 7 pro
ram 4gb
32-bit os
Replies (15)
Message 2 of 16
S.Faris
Is it only in a particular files or any files?
What is your Autocad Version? Is it updated?
if not update from here : Update Software in Autodesk Account
SALMANUL FARIS
Message 3 of 16
imadHabash
There are many reasons for such a problem , let's try with :
  • start your AutoCAD from another windows user log in , then see if any changes .
  • Reset your AutoCAD settings . >> Click <<
Imad Habash
Message 4 of 16
Hi faris,
not at all files occured.
autocadd 2013.
how do i know update status ?
thanks 🙂
Message 5 of 16
S.Faris
Use command -RECOVER and open your file and see if it shows any error.
Or maybe your file is corrupted, Follow this post : AutoCAD crashes due to Fatal Error when copying to clipboard in AutoCAD
Use Command -ABOUT and see if you have Service pack 2 shown after Autocad 2013 product version, if not download it from here : AutoCAD 2013 Downloads
SALMANUL FARIS
Message 6 of 16
here troubleshooting report from my pc. what is acad? incompatible ?
Message 7 of 16
S.Faris
What is your OS? Windows 10?
SALMANUL FARIS
Message 8 of 16
imadHabash
i suggest to follow this link >> Click << that may help .
Imad Habash
Message 9 of 16
i did the reset setting. still not solve. another error low memory is occured.
i may try to reinstall. tq
Message 10 of 16
window 7 pro
Message 11 of 16
S.Faris
Did you install Service pack 2? Can we have a look at the file?
SALMANUL FARIS
Message 12 of 16
i see.
but, its just happened this few day.
im thought that it may due to overload of memory need to cleaned up or else. since i used it for more than a year before.
Message 13 of 16
imadHabash
@Anonymous wrote:
i see.
it sounds that a new thing that occur this issue like registry cleaner , Windows Updates, new installation , antivirus scan .
Imad Habash
Message 14 of 16
morning. Smiley Happy
here attached my license info. tq
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
Message 15 of 16
You may have a dirty file. Try getting the ZombieKiller applet and purging the dwg file of any proxies that you may have gotten from other files.
https://apps.autodesk.com/ACD/en/Detail/Index?id=1498235021060360128&appLang=en&os=Win32_64
This has helped my tremendously. It's a good idea to do this to all of you work blocks as it will not only make all the blocks smaller in size but will also make AutoCAD take up less resources for large projects.
On top of this DGN Purge hotfix is also a must for AutoCAD 2013.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Message 16 of 16
thanks for great support.
im already uninstall 2013 and install 2016.
seems okay until now. just my file memory keep low and force to shut down suddenly.
lets try this zombiekiller. 🙂
