FATAL ERROR : Unhandled e0434352h Exception fe01aaadh
Message 1 of 25
Crash after opening any drawing. Happens within 2-10 minutes after drawing is open and doing normall operation such as zooming in and out, drawing a line , etc.. But most of the time, can make it crash by zooming in and out.
Tried the following already:
-Unistall 2015LT and installed 2013 , same problem,
-Unistalled 2015lt, including .NET files and C++, and then re-installed, same problem
-Updated my video card driver
-disabled hardware acceleation
nothing will fix this problem.
Replies (24)
Message 2 of 25
My current configuration is as follows:
Card name: Intel(R) HD Graphics 4000
Driver version: 9.17.10.3517
Tuning Date: 06/03/2015
Virtual device: Dx11 (Hardware)
The card and driver meets the recommended requirement.
Display Adapters:
NVIDIA Quadro K2000M (Primary)
RDPDD Chained DD
RDP Encoder Mirror Driver
RDP Reflector Display Driver
mv video hook driver2
EPSON Projector Support Driver for NP
Certification:
Hardware Available True
Hardware Recommended False
Status 4
Hardware ID 2
Hardware Feature Level 50
Software Feature Level 45
General Options:
Adaptive Degradation True
Discard Backfaces True
Dynamic Tessellation True
Generate Vertex Normals False
Handedness Right
Maximum LODs 6
Redraw on Window Expose True
Surface Tessellation Tolerance 92
Transparency MediumQuality
Additional System Information:
ComputerSystem
Manufacturer Dell Inc.
Model Precision M4700
NumberOfProcessors 1
TotalPhysicalMemory 8457617408
Processor
MaxClockSpeed 2701
Name Intel(R) Core(TM) i7-3740QM CPU @ 2.70GHz
NumberOfCores 4
NumberOfLogicalProcessors 8
Revision 14857
OperatingSystem
Name Microsoft Windows 7 Professional |C:\Windows|\Device\Harddisk0\Partition3
OSLanguage 1033
ServicePackMajorVersion 1
ServicePackMinorVersion 0
TotalSwapSpaceSize
TotalVirtualMemorySize 16516932
Version 6.1.7601
DiskDrive
Model ST320LT007-9ZV142
Name \\.\PHYSICALDRIVE0
Size 320070320640
DesktopMonitor0
MonitorManufacturer
MonitorType Default Monitor
Name Default Monitor
ScreenHeight 1080
ScreenWidth 1920
DesktopMonitor1
MonitorManufacturer
ScreenHeight 1080
ScreenWidth 1920
DesktopMonitor2
MonitorManufacturer
ScreenHeight
ScreenWidth
DesktopMonitor3
MonitorManufacturer (Standard monitor types)
MonitorType Generic PnP Monitor
Name Generic PnP Monitor
ScreenHeight
ScreenWidth
DisplayConfiguration
DeviceName mv video hook driver2
DisplayFrequency 60
DriverVersion 6.0.6000.16386
PelsHeight 768
PelsWidth 1024
VideoController0
AdapterDACType
AdapterRAM
ConfigManagerErrorCode 0
CurrentHorizontalResolution 1920
CurrentVerticalResolution 1080
DriverDate 20070411000000.000000-000
DriverVersion 6.0.1.0
InstalledDisplayDrivers
Status OK
TimeOfLastReset
VideoArchitecture 5
VideoModeDescription 1920 x 1080 x 4294967296 colors
VideoController1
AdapterDACType
AdapterRAM
DriverDate 20110708000000.000000-000
DriverVersion 1.0.0.0
Name EPSON Projector Support Driver for NP
Status OK
TimeOfLastReset
VideoArchitecture 5
VideoController2
AdapterDACType Internal
AdapterRAM 2214592512
DriverDate 20140320000000.000000-000
DriverVersion 9.17.10.3517
InstalledDisplayDrivers igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Name Intel(R) HD Graphics 4000
Status OK
TimeOfLastReset
VideoArchitecture 5
VideoController3
AdapterDACType Integrated RAMDAC
AdapterRAM 2147483648
DriverDate 20150426000000.000000-000
DriverVersion 9.18.13.4807
InstalledDisplayDrivers nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Name NVIDIA Quadro K2000M
Status OK
TimeOfLastReset
VideoArchitecture 5
Process Information:
Loaded ARX and CRX Modules
acapp.arx
acapp.crx
acgsconfig.arx
acgsconfig.crx
acvmtools.crx
accloudconnect.crx
acconnectwebservices.arx
aclaunchnfw.arx
acsign.arx
acltutil.arx
acsavevp.arx
acjscorestub.crx
acdim.arx
acdim.crx
AcFdUi.arx
acexperience.arx
acpublish.crx
acseek.arx
acsecopt.arx
Effects:
ACAD_LineSmoothing supported turned on
ACAD_PerPixelLighting supported turned on
ACAD_AdvancedMaterial supported turned on
ACAD_FullShadows supported turned on
ACAD_TextureCompression supported turned off
Message 3 of 25
Also, some error messages I found on windows logs. Not sure if they are related to the root cause of the problem or just a consequence of the crash.
When installing autocad, I got no error message dialogs.
___________________________________________________________________________________________________________
.NET Runtime Optimization Service (clr_optimization_v4.0.30319_32) - Failed to compile C:\Program Files\Autodesk\AutoCAD LT 2015\accoremgd.dll because this image is a 64bit assembly; try using 64bit ngen instead.
.NET Runtime Optimization Service (clr_optimization_v4.0.30319_32) - Failed to compile C:\Program Files\Autodesk\AutoCAD LT 2015\acmgd.dll because this image is a 64bit assembly; try using 64bit ngen instead.
______________________________________________________________________________________________________________
Faulting application name: WSCommCntr4.exe, version: 4.0.3.0, time stamp: 0x50dcb523
Faulting module name: WSCommCntr4.exe, version: 4.0.3.0, time stamp: 0x50dcb523
Exception code: 0xc0000005
Fault offset: 0x0000000000016490
Faulting process id: 0x634
Faulting application start time: 0x01d09e461a21f346
Faulting application path: C:\Program Files\Common Files\Autodesk Shared\WSCommCntr4\Lib\WSCommCntr4.exe
Faulting module path: C:\Program Files\Common Files\Autodesk Shared\WSCommCntr4\Lib\WSCommCntr4.exe
Report Id: ec52da0d-0a39-11e5-9101-b8ca3ac756ad
Message 4 of 25
Message 5 of 25
eunice.chagoya
I am experiencing the same kind of errors, but my users' case are related with havind AutoCAD 2015, and trying to user Autodesk Vault Professional 2013. Are they compatible?
Message 6 of 25
I am also getting this error now. I believe it started after recent windows updates. I'm only getting it when i click on certain objects. Ive been working around it by pointing auto cad config file to use older framework but this is causing me the same issue with different blocks. so depending on what im working on in cad I modify the config file before launching.
Message 7 of 25
Can you elaborate more on your work-around? I have not noticed any pattern with this error, other than popping up every ten minutes or so.
Message 8 of 25
pendean
Community Legend
Community Legend
Not sure if you tried it yet, but since the faulting app is he wscommctr tool, you can turn that off or uninstall it, restart Windows, and AutoCAD should work just fine without it.
Windows System Restore would be a great tool to remove updates or add-ons if you suspect that as being the culprit instead.
Message 9 of 25
I did try to turn infocenter off in the registry and made sure wscommcrt wasn't running.  But this had no impact as the problem continued.
Unfortunately I did not have system restore turned on when this started happening...
Message 10 of 25
wispoxy
Wow, your memory flush does not recognize your current operating system, but also fails a temp memory draw. Two problems going on here.
You need to make sure your AutoCAD supports your system, make sure you have enough computer memory, make sure you have the most recent update on your operating system, and if you have virus / system protection software make sure to Authorize AutoCAD. Finally, reinstall AutoCAD.
Message 11 of 25
I typed out a huge explanation / walk through and when i hit submit the forum gave me some mismatched ID error and its all gone. My fault for not writing it somewhere secure then copy and pasting it here. bummer.
Message 12 of 25
" Wow, your memory flush does not recognize your current operating system, but also fails a temp memory draw."
How did you get to this conclusion? Where did you look to notice this problem?
Thanks!
Message 13 of 25
wow. so i tried again and am not able to pose here because the forum is reading the modification to the config file Ive written out as bad HTML and kicks it back. e-mail me and i'll send it to you. aschulhoff@gmail.com
Message 14 of 25
OK. Something finally seems to have fixed the problem. I started to noticed that Autocad crashed when an objected was selected or mouse had roll over it.
After setting "ROLLOVERTIPS" parameter to off (0) the autocad ran just fine.  Since the fix my installation has been running for 2 days  without a hiccup, as opposed to getting a crash within minutes of opening a drawing and working.
Message 15 of 25
davetheplanman
That also happens to me every couple of days. I just save like crazy. My Autosave is 5 minutes & I save eveery few commands.  It's just unstable software- Auto Cad has ALWAYS crashed unexpectedly- it just has. I suppose it always will. I agree it's ridiculous- just hope you don't lose much work. PS It's always easier to draw it the second time!
Message 16 of 25
This has not been my 18 year experience with Autocad. When it crashes regularly there is always a way to fix it. While it's some times hard to figure out the fix is almost never complicated. 9 times out of 10 it's because of .net framework or graphic card incompatibility.
Sent from my iPad
Message 17 of 25
davetheplanman
Thanks for the reply & woo hoo if you're not crashing every so often, you're the luckiest man on the Earth! You need to play the lottery! I've worked for large companies, small companies, on my own, & on a broad variety of work stations. The common demoninator? ACAD crashes unexpectedly- I'm not saying a lot, just every so often- but any crash usually results in at least a small amount of rework & is just a hassle. Also- how does Auto Desk plan the crashes at the absolute WORST times! (ie massive deadline.... CRASH) It's jusy my opinion, based on years of evidence, Auto CAD is going to crash! Save, save, save!
Message 18 of 25
Abismal at best.
Install Autocad DWG Viewer 2017 yesterday, open the same drawing numerous times. With-in 10 min, ACAD crashes and Win7 PC reboots all by its own self.
This a frigging joke right?? This is a mere "viewer" meaning ALL I want to do is look at the drawing, maybe print it and autocad crashes?? Seriously??
JUNK JUNKJUNK JUNK JUNK......MORE JUNK...JUNK<JUNK<JUNK
Not only that, just installing this behemouth of a viewer was a 20 min proccess. Another JOKE I guess? More MS dot Net crap too.
So for that last 2 days, my PC has crashed 4 times, and I still havn't managed to print the drawing I need.
Pathetic!!
Edited by
Discussion_Admin
Message 19 of 25
john.vellek
Hi gilhoerbiger, Looking at these errors tells me that the user might not have the proper permissions. Try running as Local Administrator to see if the problem presents itself.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 20 of 25
davetheplanman
Welcome to the wonderful world of Auto CAD! If you're crashing every ten minutes, there's an issue! As I was saying, Auto CAD crashes from time to time- it just does. the best advice is set your save time to 3 minutes or so- I go with 5 minutes. When it crashes (it will) you've only lost a little work and it's easier the second time.
Auto CAD is a pain in the on a variety of fronts- the best we can hope for is that they go away and new software eventually takes over, or perhaps new controlling owners that care about paying (it's not exactly cheap) customers and stable software!!!!!
Edited by
Discussion_Admin
