FATAL ERROR : Unhandled e0434352h Exception fe01aaadh
Message 1 of 25
Crash after opening any drawing. Happens within 2-10 minutes after drawing is open and doing normall operation such as zooming in and out, drawing a line , etc.. But most of the time, can make it crash by zooming in and out.
Tried the following already:
-Unistall 2015LT and installed 2013 , same problem,
-Unistalled 2015lt, including .NET files and C++, and then re-installed, same problem
-Updated my video card driver
-disabled hardware acceleation
nothing will fix this problem.
Replies (24)
Message 21 of 25
If your autocad is crashing, even a rare random crash... Something is causing it. Go to your error log and see what it is then fix the problem. If you dont find the issue and fix it, its never hard, then you're the problem... Not cad.
Message 22 of 25
Well,
And lets be clear here......this is software to allow a user to "VIEW" the frigging drawing. We want to LOOK at it....that's ALL.
It Is an Autocad problem, because my PC was fine BEFORE installing this hunk of junk. And it is now fine AFTER UNINSTALLING THIS CRAP.
ABSOLUTLY IT IS NOT ........A USER or a PC ISSUE. Its an AutoCad problem, along with MS Dot Net.
Both Autocad and MS along with Adobe and Java can die off sooner than later and will make the world a better place.
My 2c after wasting 2 hours of MY time with this crappy software (which is ONLY a frigging Viewer) All I want to do is LOOK at the frigging drawing. I don;t want to draw, or create, or manipluate, or edit, or stretch it. I just want to be able to LOOK at it..
Is that asking too much??
Edited by
Discussion_Admin
Message 23 of 25
Then this is one of those instances where you shouldnt spend anymore time trying to fix the issue. You should higher someone who is capable of understanding whats wrong and correcting it. It will only take that person a few seconds of their time to know whats wrong and have you all set up...
Message 24 of 25
just cause i feel for your fustration, if you want to email me the drawing, ill plot it to pdf and send it back to you. Aaron@firewaterdesign.com
Message 25 of 25
davetheplanman
FYI anybody that says that ACAD does not randomly crash is either the
luckiest person alive... or.... they haven't really used much ACAD because
ACAD crashes- it does, not a lot but it most definitely crashes (any crash
is a pain in the rear). Anybody that uses ACAD for a living knows that,
and as a result knows to save a LOT!!
Hang tough- it doesn't get much better! Sorry for being the bearer of
reality!
Good times!
