FATAL ERROR: Unhandled e0434352h Exception at 606b7788h
Message 1 of 8
Hi everybody, when I close my AutoCAD drawing and do not save it this FATAL ERROR message appears (FATAL ERROR: Unhandled e0434352h Exception at 606b7788h)...
I have AutoCAD 2016..
Help me please, I dont understand why this bug appears...
Thanks and have a nice day !
Accepted solutions (3)
Replies (7)
Message 2 of 8
imadHabash
I suggest to follow this >> Link << .. hope it's help.
Imad Habash
Message 3 of 8
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
This likely indicates that your drawing is damaged or corrupt. You can attach it to a post if you like.
I recommend that you run AUDIT on your file to see if it can repair any errors.
If the error persists, the message you are seeing might be related to the installation of C++ on your workstation. You can review this article to see it helps.
John Vellek
Message 4 of 8
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post solves your issue or answers your question.
John Vellek
Message 5 of 8
Thanks for your suggestion, finaly I following the solutions on this link :
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-...
and after try all solutions my issue is resolves !
Thanks a lot ! 🙂
(Sorry for my english, it's not perfect)
Message 6 of 8
Thanks a lot ! 🙂
Message 7 of 8
I m also getting same error please help me out
@john.vellek wrote:
Hi @Anonymous,
Message 8 of 8
Alfred.NESWADBA
What have you tried from the previous suggestions and links?
Some additional info's could be helpful:
  1. When do you get the exception?
  2. What version of AutoCAD do you have?
  3. Which graphic card do you have?
  4. Which operating system do you have?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
