fatal error unhandled e0434352h exception at 1851cb69h
aymankh193
aymankh193
Community Visitor
Community Visitor
i got this meesage when opening , fatal error unhandled e0434352h exception at 1851cb69h , on autocad 2023
imadHabash
Hi and Welcome to AutoCAD Forum,
Such problem cannot be directly caused.. Rather, we have to search and start trying some solutions that may help us.I suggest try google search to find and follow some solutions . >> Click <<
All the best ..
Imad Habash
jayhar
Here are a few steps you can try to resolve this problem:
1. Update AutoCAD: Ensure that you have the latest updates and service packs installed for AutoCAD. Updating the software may fix any known issues or bugs that could be causing the error.
2. Repair or reinstall AutoCAD: Use the installation media or installer package to repair or reinstall AutoCAD. This process can resolve issues related to corrupted or missing program files.
3. Disable third-party plugins: If you have any third-party plugins or add-ons installed in AutoCAD, try disabling them temporarily. Sometimes, conflicts between these plugins and AutoCAD can trigger fatal errors. If disabling the plugins resolves the issue, contact the plugin developer for assistance or check for any available updates.
4. Reset AutoCAD settings: Resetting the program settings to their default values may help resolve the error. You can do this by running the "Reset Settings to Default" command in AutoCAD or by manually deleting the configuration files. Note that resetting settings will remove any customizations you have made, so it's advisable to back up your settings before proceeding.
5. Check system requirements: Ensure that your computer meets the minimum system requirements for AutoCAD 2023. Inadequate hardware specifications can lead to instability and errors.
Remember to back up any important files or projects before attempting any troubleshooting steps to avoid data loss.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
