FATAL ERROR: Unhandled Access Violation Reading 0x0028 Exception at E48642F0h
不适用
16,849 次查看
9 条回复
1 条消息(共 10 条)
不适用
I get this error when I start AutoCAD 2020. I am using Lenovo ThinkPad E490 with Radeon RX 550x. Operating system Windows 10.
So far I have tried the following without any success:
  • Clean temp files;
  • Update both Intel UHD and Radeon drivers;
  • Install all Windows Updates (manually thought Settings/Windows Update);
  • Uncheck the "Validate digital signature and display special icons" through "acsignopt.exe;
  • Repair AutoCAD; and
  • Re-install AutoCAD;
Everytime I rebooted my PC.
It is important to say that this problem appeared today, right after I installed the AMD Radeon Software.
At this point I cannot think of anything else to try. Any help will be highly appreciated.
Thanks in advance.
已接受的解答 (2)
16,850 次查看
9 条回复
回复 (9)
2 条消息(共 10 条)
Cadologist
There may be some additional things for you to try in the link below, from the Autodesk Knowledge Network regarding AutoCAD freezing, hangs or crashes at start up....
Question - when you uninstalled, reinstalled AutoCAD, did you do a 'clean uninstall' using the procedure as linked within the article below?
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Program-...
Chad Franklin
0 个赞
3 条消息(共 10 条)
不适用
已接受的解答
I have updated radeon graphics driver too... and faced the problem. I got the solution too
As it is problematic because of radeon driver... Why don't we run AutoCAD by our default graphics...
Here is the process :
1. Go to Settings
2. Go to System>Display
3. Go to Graphics Settings(At the end)
4. Browse app(If AutoCAD is not present there), then make it to power saving.
5, Exit and Run AutoCAD ...
Done... Enjoy
This method worked for me... Let me know if it does/does not work for you....
4 条消息(共 10 条)
不适用
I tried a clean uninstall and now I cannot even install AutoCAD 2020.
I get the following error when the install process starts:
"Error downloading. Please Install Now again fro the Autodesk website".
Also check the attached photo.
0 个赞
5 条消息(共 10 条)
Cadologist
This should help....
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Setup-...
Chad Franklin
0 个赞
6 条消息(共 10 条)
不适用
已接受的解答
Watch this video...
Hope this helps...
7 条消息(共 10 条)
不适用
Thx a lot. It worked.
8 条消息(共 10 条)
不适用
wow, that work in my laptop- Dell v3568 core i5
thanks you so much bro
9 条消息(共 10 条)
不适用
Jazakallahu Khair. This worked for me. Appreciate your good solve. Keep it up, buddy.
10 条消息(共 10 条)
不适用
me sale ese error agradeceré me ayuden con una solución
0 个赞
