I am user of AutoCAD 2012 and a beginner in 3d. I made this 3d box culvert drawing in Acad2012 and tried to render it, but the program abort and gives the message: fatal error: unhandled access violation reading 0x0000 exception at 328162a0h. I did search in the web and a possible solution was that the reason is that the medium library has to be downloaded because not everybody uses it, and for that reason it's not installed with the program. I tried this solution, went to autodesk and downloaded it and installed it. Apparently it is installed ok, but when I open the drawing and try to open the render library the same message appears and abort program. 😞 And attachment is available for checking. Thanks in advance to whom may help.
