I installed autocad 13 freeshly. while open a folder for application, screen is forced to close and displays :
FATAL ERROR unhandles acces violation reading 0x000 exception at d7b4ad66h
I could not find the reason for that error. I request for your help..
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
What is your operating system? Does your system meet the minimum system requirements?
Have you checked to see if your Windows is up to date and that you have current graphics card drivers installed?
Hello sir, i install windosw 10 and there is no problem now. It works very good. thanks a lot.
