Fastest way to create 3d lines (poly or normal) with offsets from text levels?
11:42 PM
tl;dr: Fastest way to create lines to the correct manhole levels along the runs? I have positions and text levels....
Hey guys, I'm at work, and I have this network of drains, the objective is to create 3D lines along the runs, then create a 1200mm wide surface at inv level along the runs to use in a machine control file for digging with an excavator. My usual method is to draw 3D polys along the runs, change each vertex to the correct level, then offset the lines 600mm either way and use that to create a surface in LSS. But I feel like there must be a quicker way of doing it? Everything is flat since I converted it from a PDF, thanks in advance for any help!
