facing mirror problem
Message 1 of 11
hello people, i am facing a problem in my CAD 2010, that when ever i enter a text and hit enter the text appears visevers (mirrored) and when ever i copy and paste something it appears and mirrored object. Need help please!! thank you!
Replies (10)
Message 2 of 11
Verify that the current text STYLE is not set to BACKWARDS.
Message 3 of 11
that's not set, not only text but if i copy any thing and paste it it appears mirrored.
Message 4 of 11
Kent1Cooper
You may be "looking" at your drawing from underneath as a result of something like a VPOINT or DVIEW command.   Make sure you're in Plan view [PLAN command, current UCS].
Kent Cooper, AIA
Message 5 of 11
Kent1Cooper beat me to it.  Smiley Happy  Verify your View, be sure you're not looking underneath the drawing.
Message 6 of 11
No its in the plan view itself.
Message 7 of 11
no sir, its the plan view. not the underneath. my plan is correct, only the thing is the text and object copied appears mirrored.
Message 8 of 11
Can you upload the drawing?  Its hard to diagnose this without the DWG.
Message 9 of 11
Message 10 of 11
Patchy
Turn your UCS icon ON
It clearly shows you're not using world UCS.
to fix it:
UCS use w
PLAN use C
Message 11 of 11
thank you 🙂
