Extruding an object using the distance between two points as extrusion height?
I mainly use cad for furniture. I used vs 2005 for years. When the front and side views were done I would start working on the 3D, using the front and side views as reference. In 2005 there was the option (in extrude) that once the object is selected, you can click two points to tell it what distance to extrude it. It was very simple because working with the front view, the extrusion depth was easily determined by the side view depths.
With 2014, this option seems to have been removed. Extruding along a path is still there, so is pointing to 1 point (using the face as a starting point), but there doesn't seem to be a way to point from one point to another where that distance is the distance that you want to extrude.
Anyone know if there's any way to reenable it?
