AutoCAD Forum
Extruding a surface by its centre
3 REPLIES 3
653 Views, 3 Replies
Afternoon,
Is there a way to extrude a surface (loft) by its centre and not from the side?
So its in the middle without having to go back and move the "wall" back to the middle?
Thank you.
3 REPLIES 3
JDMather
You mention both Extrude and Loft.  Not sure which one you really mean, and without example file or at least a picture - I assume you mean something like the mid-plane (Symmetric) Extrusion in Autodesk Inventor.
I don't think there is a way to do that in one step in Autodesk AutoCAD.
If this doesn't really describe your design intent - please provide more information.
in reply to: JDMather
That would be perfect if i was using Inventor. thank you though for you help.
Alfred.NESWADBA
if it's really an open surface you can try:
  • set DELOBJ to 0 so it will not be erased after command _THICKEN
  • run command _THICKEN with a positive value
  • run command _THICKEN with a negative value
creates 2 solids from your "center"-surface to each side.
To be careful: as every type of offset it might happen, that you can't UNION then both objects. This depends on the situation(s).
Here you can see a black surface, a green 3D-Solid created with a positive value and a red 3D-Solid created with a negative value for command _THICKEN
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Technology Administrators
AutoCAD Beta
