Using Extrim Command, circles dimensions under 1mm are not cutted, under a boundary of 300mm circle. (Please see screenshot)
Can someone explain me how can i overcome this problem?
Thanks in advance
Thanks in advance
i think the area of ∅300mm circle is cause this issue . when picking inside the circle to finish the command and start scanning i notice this issue . i think if you ignored that big area for the circle and trim it ( as seen below ) the issue will resolved .
Imad Habash
Imad Habash
Thanks for your reply, but I have thousands of balls across the 300mm Circle.
My really intention is to avoid go around the 300mm circle cutting or deleting the little Circles/Objects, this take me a long time.
Is there any Lisp that can help me overcoming this problem?
Do you have knowledge in Lisp? Then i would like to show you how to.
If not and you have only few circles - Use the imhads workaround and create smaller arc parts as trim object.
or if you have only one 300-Circle and 1000 small circles for trimmig, upload your file - i will see what i can do for you (this one time).
Sebastian
Sebastian
