Extracting edges from Point Cloud is not working on .rcp file in AutoCAD 2020
bageseabraham
bageseabraham
Hi All,
I am trying to extract edges from the point cloud, but it is not working.
Please see the screencast. https://autode.sk/3gVkWoB
I am currently working with .rcp file.
Also, I have noticed the section not cutting the object; it's only showing the section plane.
Abraham
@bageseabraham
Topic Title has been changed by @Tiana_Y for better findability. Original: Point Cloud Section
cheryl.buck
Autodesk Support
Autodesk Support
Hi @bageseabraham,
That is unusual. Thank you for the ScreenCast. I have not seen the result Section Object Not Found when selecting the point cloud before.
I found this thread that appears to be related. @Alfred.NESWADBA included a ScreenCast of his process.
Let me know if this helps.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
