Hi all,
I'm exported two .RCS files from Recap - one with 1mm Unify settings and one at 5mm.
When I xref these into AutoCAD, I can see them and section them, but I can't use the geometry extraction tools - they just don't recognise any planes or features.
I found the link below which seems to indicate that it won't work if the scan contains segmentation data.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Cannot-extract-edg...
When I view the properties for my scans I can see that they have a 'yes' next to segmentation data.
How do I make this work? There are no settings in Recap for this option. I have used the same work flow in the past without a problem...
Any suggestions?
