AutoCAD Forum
external references
7 REPLIES 7
Message 1 of 8
344 Views, 7 Replies
external references
Hello all!
I am totally stuck on a project.  I need to do a simple electrical grounding drawing(2d) but i have plans that were given to me with tons of xrefs(3d) in the drawing and about a million layers.  i can barely navigate through the drawing.  Anyone have any suggestions of how i can explode these xref"d drawings and put condense them all into one layer?
-Joe
Autocad 2016
Dell i7 8 core
windows 7
16G ram
external references
Hello all!
-Joe
Autocad 2016
Dell i7 8 core
windows 7
16G ram
7 REPLIES 7
Message 2 of 8
jackshield
jackshield
bind xrefs as blocks and work from there
Message 3 of 8
in reply to: jackshield
i tried that Jack, they would not bind due to a proxy error.
Message 4 of 8
Message 5 of 8
jackshield
jackshield
do you have the xref files?
Message 6 of 8
yes
yes
Message 7 of 8
paullimapa
paullimapa
One quick way maybe to create a dwf from the drawing with all those xrefs which will combine everything into a single layer and then in a new drawing attach the dwf and then you can draw over it with your electrical grounding.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
Message 8 of 8
neaton
neaton
If you know you only need the wall layers use the XLIST command to determine the wall layer names. Once those are determined you can turn off the layers you don't need in the XREFs in the Layer Manager.
AutoCAD Inside the Factory
