External Reference File has Changed
lbengineer
Message 1 of 9
lbengineer
Is there a setting I am missing for external references? If I save a drawing and close it with another file open that is referenced to that file it asks me every time if I would like to reload it. Can we just have it load automatically? I don't see a time when I would not want it to reload. Thank you in advance for your answers. I'm using AutoCAD 2020.
Replies (8)
Message 2 of 9
imadHabash
i'm afraid that you have a conflict in the attached xref path name .
Imad Habash
Message 3 of 9
lbengineer
Thanks for your quick response, but it doesn't answer the question.
Message 4 of 9
Alfred.NESWADBA
Am I correct that you are using SDI = 1?
Otherwise a drawing would not be closed when you open a second dwg-file.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 5 of 9
imadHabash
if you make a new simple drawing ( just lines ) and you attached it as an xref in a new other drawing , does the same issue happend ?
Imad Habash
Message 6 of 9
lbengineer
My SDI = 0
Message 7 of 9
lbengineer
Yes it is only asking me to reload when I have multiple files open. Then I make a change to the external reference file and tab to one of the open files. is there a setting to automatically load without clicking reload ex ref?
Message 8 of 9
RobDraw
No.
Rob
Message 9 of 9
lbengineer
Thank you. Maybe some day. Smiley Frustrated
