Exposure Value in View Base Sections
Hello all,
I work for a design firm creating designs for Ice shows. We have started using View Base Sections but we are having problems with the exposure value in the view bases being darker than in regular view-ports. I know you can change the exposure value for regular view-ports,because we adjust that already, but is there a command that can adjust the exposure value in the view base windows?
Mark Schmidt
Hotopp Associates, Ltd.
imadHabash
same question from the same person here in this solved post !! >> Click <<
Imad Habash
john.vellek
Hi @m.schmidt,
I don't believe this is possible with ViewBase views.  EXPVALUE is designed to work with the RENDER command.  This can not be executed in paperspace which is where the Viewbase views reside.
John Vellek
