exporting STEP files in autocad 2020
Message 1 of 9
I am trying to export STEP file in AutoCAD 2020 (including specialised toolsets). May i know the method to output my autocad file to STEP file?
Accepted solutions (3)
Replies (8)
Message 2 of 9
ennujozlagam
check this if helps. thanks
  1. At the Command prompt, enter STEPOUT.
  2. In the STEPOUT Translation dialog box, in the Files of type box, select *.ste,*.stp, or *.step.
  3. In the File Name box, specify the name of the STEP file.
  4. Click Save.
Message 3 of 9
Alfred.NESWADBA
You need to start the Mechanical Toolset (AutoCAD Mechanical).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 9
Thank you but message shown: "unknown command STEPOUT"
Message 5 of 9
ennujozlagam
hello, that means you need to follow @Alfred.NESWADBA  suggestion start with Mechanical toolset or you can refer to these LINK and LINK. thanks
Message 6 of 9
Hi Alfred,
Thanks a lot. I did it! Such clumsy i am to deal with it.
Thank you. ^O^
Ten It
Message 7 of 9
Yes, you are right. I followed Alfred's suggestion by opening the autocad mechanical 2020 (not autocad 2020) and .... I got it!
Thank you for your patient in sharing with me. ^O^
Ten It
Message 8 of 9
AIR_123
STEPOUT is unknown command in Acad Mechanical 2022... Any suggestions how to fix this?
Message 9 of 9
AIR_123
