Exporting autocad dwg to stl file
zdk10
Observer Observer
zdk10
Observer
Observer
Im having trouble exporting my dwg file to an stl file. When I try to export and save the document it doesnt actually convert and save to my computer. I have even tried using online converters and it just shows me error messages. Help please!! I have attached the files.
imadHabash
to get a stl file you must have solid objects or watertight meshes . All objects must be entirely within the positive XYZ octant of the world coordinate system (WCS). That is, their XY, and Z coordinates must be greater than zero.
you only have 3d faces !!
Imad Habash
Tiana_Y
Hi @zdk10
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD forum! I'm just checking in to see if you need more help with this. Did the information that @imadHabash provided help you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
zdk10
Observer
Observer
How do I go about turning those into solid objects or meshes. Also the original design before I added my own stuff was an stl file and it didn't have any solid objects or meshes I have attached those files.
