Exporting 3d model from autocad to PowerPoint
yu85.info
yu85.info
Hi, I wish to export a 3D model from Autocad and insert in my PowerPoint presentation as a 3D model.
Is there a way to do this and keep all the colors (I mean that the model will not be all gray)
I attached a DWG file.
Thank you very much for your help
ennujozlagam
https://thecadgeek.com/blog/inserting-dwgs-into-ms-word-or-powerpoint/
yu85.info
Thank You. but I wish to insert a 3D model. In this link It explains how to
insert a simple 2D drawing.
In the PowerPoint there is an option to insert 3D models but I dont know
how to export from autocad a 3D model to a file that is supported by
PowerPoint
Thank you again sir
ennujozlagam
in autocad go to your 3d view > in the command prompt type JPEGOUT and insert this file to your powerpoint>
ennujozlagam
https://www.cadforum.cz/en/how-to-insert-your-3d-model-into-a-powerpoint-presentation-tip12884
pendean
Community Legend
Community Legend
@yu85.info PowerPoint is not a 3D modelling program: never has been, still is not. What you asked for is not possible: but you can past a picture of your model in there. See link above from another responder or use the follow for the same but quicker process https://support.microsoft.com/en-us/help/13776/windows-use-snipping-tool-to-capture-screenshots
yu85.info
Yes you are right. But there is an option to insert a 3D object for
presentation. Insert--3d model. In this option you can add .obj file or fbx
file. The problem is that I that I am trying to export the model with its
color and not in grayscale.
