>> however in the pdf file the colours are present
Have you exported the PDF or have you used _PLOT with the assiciated CTB?
And to the colors: are these colors true-color or color-index colors (from 1 to 255), only the index values can be converted with CTB, true color stay as true color.
Last but not least: what visual style did you use? If that is a rendered style like "realistic" the colors are converted to true color and so not converted by CTB, use a visual style like "2D-Wireframe" instead.
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2024------------------------------------------------------------------------------------
(not an Autodesk consultant)
