AutoCAD Forum
Export to PDF DIN A0 and A1 possible?
3 REPLIES 3
rattlesnakeNo1
1759 Views, 3 Replies
rattlesnakeNo1
it looks like, that AutoCAD has no option in PDF export for page setup (DIN A1 or DIN A2) .
Maybe there is a trick or someone knows a good additional tool for PDF print in DIN A1 oder DIN A2?
It’s not a bug – it’s an undocumented feature
Labels (1)
3 REPLIES 3
cadffm
in reply to: rattlesnakeNo1
cadffm
Your setting is "Pagesetup: CURRENT", so it uses *what ever is your current pagesetup*
Start PLOT command oder PAGESETUP to see your pagesetup.
- Another question: Why are you using EXPORTPDF instead of PLOT command?
Back to ExportPDF:
You can override the pagesetup for your ExportPDF step, choose "Override" instead of Current,
then use the button [Page setup Override]
Sebastian
Back to ExportPDF:
Sebastian
pendean
pendean
Community Legend
Community Legend
No bug, just a bad workflow you've chosen: EXPORTPDF is not the correct tool if you need critical controls if you never plan on editing the PAGESETUP command settings first: PLOT command is one step to do it all in one place.
rattlesnakeNo1
in reply to: cadffm
rattlesnakeNo1
Thanks! 😀
Works perfect!
I thought that I also find this option in Inventor. But there ist
no printer like this in the pull down menü. PDF export
also not working for A0 or A1.
Maybe someone can help? If not I will post this question in
the inventor forum.
Thanks! 😀
Works perfect!
the inventor forum.
AutoCAD Inside the Factory
