Export to dwg with image binding
Message 1 of 11
How do I export to dwg with images binded into one file rather than separate files?
Replies (10)
Message 2 of 11
imadHabash
I think that you're asking for ETRANSMIT command.you can make your own settings from Transmittal setup.
Imad Habash
Message 3 of 11
Hi Imad,
Etransmit is for exportig Revit not to dwg
Message 4 of 11
Alfred.NESWADBA
Are you speaking about Revit? Then you are at the wrong forum, Revit is discussed >>>there<<<.
Otherwise please let us know what you mean by "Etransmit is for exportig Revit "
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 11
Oops sorry, Revit to DWG.... wrong forum
Message 6 of 11
imadHabash
>> Etransmit is for exportig Revit not to dwg <<
NO..you can do it for dwg files. read Here for more information.
Imad Habash
Message 7 of 11
Hi Imad,
I've set Etransmit to bind but I still get a folder with reference files.
It is not binding into one file.
Message 8 of 11
pendean
Community Legend
Community Legend
Are you using REVIT or AutoCAD?
Message 9 of 11
Yes I'm using both Revit & AutoCad. But I understand this is AutoCad forum so I'll only ask about AutoCad binding image using Etransmit.
Message 10 of 11
pendean
Community Legend
Community Legend
Good: move the top file out of the etransmit folder in question to break any possible file links, and open it. Are the xrefs bound or is the top file still trying to find them to reference in?
Message 11 of 11
Host file shows Image paths only
