HI,
>> It contains a table of text.
Nope, it does not contain a table, not an AutoCAD object "Table".
These are just text-, mtext- , line- and polyline-objects, sometimes 2, sometimes 3 (m)text-objects in one "virtual" cell, so not well structured.
If you have a bit knowledge of programming you might write your tool to get that first in a well structured table, or maybe to a CSV. But I don't know any tool AutoCAD has OOTB that can export this geometry to a (structured) Excel spreadsheet.
>> What are the disadvantages of using the OLE command
>> to get the texts in the CAD file?
Do you mean "to use OLE objects in AutoCAD"? ... The biggest disadvantage is that sometimes it makes it hard to print (either invisible on print, sometimes 90° rotated, sometimes fonts destroyed).
My personal opinion is that I avoid OLE as long as possible.
Sorry, - alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
