- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When Export PDF command is selected from the Output tab the error dialog box below appears, ok can be selected and the expected Save as PDF dialog box appears. Select save and the error box displays again, you can select ok and then pdf is created ok.
The dialog box cannot be expanded to see the rest of the error which is frustrating.
We have just had AutoCAD 2017 installed but our previous issue of 2016 had the same problem but only on one of our workstation's, now it's on both.
This error dialog box does not display through the normal plot routine and the pdf's are created as expected.
I have copied the out of the box PC3 files for DWG To PDF variations (high quality, web use etc) to our shared 'plotters' folder and tried them all.
The error is not causing a crash, it's just annoying as it's nice to have the software performing smoothly.
Thanks in advance for any help
