EXPORT LAYOUT
EXPORT LAYOUT
sandrasmithLRP57
EXPORT LAYOUT
sandrasmithLRP57
Why is the full extent of my inserted .jpg in the view port visible in the new Model Space drawing created by EXPORTLAYOUT?
pendean
Community Legend
Community Legend
AutoCAD does not clip raster images.
sandrasmithLRP57
Thank you. Good to know - so what would be the solution to that
Also, what about OLE that has been inserted in the original Layout? They as well as Data links disappear too
sandrasmithLRP57
Thank you. Good to know – so what would be the solution to that
pendean
Community Legend
Community Legend
You will need to edit/trim your raster image prior to placement in the layout: and keep in mind referenced content (including linked OLEs and datalinks) are not going to self-attach and travel along. Known limitations.
Perhaps you should PLOT your layout to a PDF, then PDFIMPORT it into a blank/empty DWG file for a similar effect? If sending your original and all supporting files (like through ETRANSMIT command) is not an option.
