Dear All,
Im using AutoCAD 2016. Anyone could advise me how to export selected layer in AutoCAD to shapefile format?
Regards.
Solved by Alfred.NESWADBA. Go to Solution.
AutoCAD does not support the GIS-dataformat "SHP", you'll need either AutoCAD Map 3D or AutoCAD Civil 3D (which includes most of the Map 3D functionality) or you need to use other products like e.g. QGIS (free >>>click<<<), where you can import a DXF and export a SHP from the DXF.
Good luck, - alfred -
Hello Alfred.
Thank you for the reply. I guest I have to look other work around to transfer these layers into my ESRI map.
Regards.
Do you have ArcGIS? Then simply save your drawing as DXF2010 and import that DXF into ArcGIS.
- alfred -
Hello Alfred,
Thank you for the solution given. I can load the layer to my ARCGIS. Im very glad the file can be load now. You save my day.
Regards.
you are very welcome, glad I was able to help!
Have a great day, - alfred -
