AutoCAD Forum
export import layer states
3 REPLIES 3
DGRL
511 Views, 3 Replies
Dear forum members
I want to copy all layers from 1 dwt to another
I use Layer states (export import) for that
What i notice is that the plot style( i use stb instead of ctb) is not updated correctly if not at all
I have a few layers specific;y on plot style 4 but after importing the *.las file the layers wil get another plot style (i.e 1 or 2 or normal)
What am i doing wrong ?
I need to transfer a lot of layers and i need the plot style setting to be transfered also
If this was of any help please kudo and/or Accept as Solution
Kind Regards
3 REPLIES 3
cadffm
in reply to: DGRL
Don't use *.las for import/export, import the layerstate from your DWT (or DWG) directly.
Sebastian
DGRL
in reply to: cadffm
@cadffm
Tried that does not work
Can it be because i want to transfer layers from A1 template to A2?
Coz between A1 templates it works but when i open the A2 template it fails
Getting message "Restore could not restore all plot styles"
Kind Regards
DGRL
in reply to: cadffm
@cadffm
After getting out of project settings and loaded it again the dwt option works perfect
Kind Regards
AutoCAD Inside the Factory
