export autoCAD file to Proteus
Could you please tell me how it is possible to export an autoCAD file to Proteus? The reason is that I would like to import an autoCAD file into another software and as far as i know this is the only way to be done. Thank you
Alfred.NESWADBA
welcome @forums.autodesk.com!
What is Proteus (besides of >>>the god in the greek mythology<<<)?
Give us links, also info's about what interfaces that software accepts.
Why not mention what software this is, maybe someone knows a direct way so you don't have to go through 2 different interfaces (and each having it's own banana skin).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thank you very much for your reply!
I would like to import some autoCAD files into COMOS Software (Siemens).
This import is not possible for the moment.
After a discussion I had with COMOS Support they proposed to export autoCAD
files to Proteus and then import them into COMOS.
As far as I know, Proteus is electrical CAD software for
electrical/electronic design. And that is my problem. I have no further idea
about it.
Do you have any suggestions?
Thank you,
Kind Regards
Philippos Constanti
Physicist - Environmental Consultant
Description: Description: Topomaster
Phone: +357 22 819370
Mobile: +357 99 352306
Fax: +357 22 453043
E-Mail ph.constanti@topomaster.com
Internetwww.topomaster.com
Address: Topomaster Ltd - 10 Democratias Avenue, Serifos Building , Suite
102 , Ayios Dometios, 2370, Nicosia Cyprus
Confidentiality Warning - Disclaimer: This e-mail contains information
intended only for the individual or entity to which it is addressed and may
contain confidential material. If the reader of this e-mail is not the
intended recipient or the employee or agent responsible for delivering it to
the intended recipient, any dissemination, copying or other use of, or
taking of any action in reliance upon this e-mail is strictly prohibited.
The sender bears no responsibility for any loss, disruption or damage to
your data or computer system that may occur while using data contained in,
or transmitted with, this e-mail. If you received this e-mail in error,
please immediately notify the sender by return e-mail and delete the
material from any computer. Any views expressed are personal unless
otherwise stated
Alfred.NESWADBA
found by Google >>>that PDF<<<, download it and look to chapter
   1.6 Exporting and Importing DWG/DXF files
There you can see that DWG-files up to DWG format 2010 is directly supported (I don't know if the PDF is a current one or not, so it has to be verified).
So either the name "Comos" is not a product name, but more something like a product group or a system that contains many modules (each handling different jobs) or the people from Siemens might have missed something.
In the first case (multiple modules/...) we need more info about what module/... you are speaking about.
Are you shipping electrical plans?
My guess for that is: when a software handles electrical parts then every data-exchange of geometry not known by that system will not work.
>> And that is my problem. I have no further idea about it.
Not knowing the product will make the handling of the interface more complex than just export and import.
Let the Siemens people show you were to find "Proteus" in the www and what interfaces they provide.
- alfred -
Alfred NESWADBA
pendean
Community Legend
Community Legend
Proteus the PCB /micro boards design software? Are you designing circuit boards? Looks like you have to buy Proteus to import cad files to create "proteus" files for your Siemens product.
