AutoCAD Forum
Explorer must start when opening autocad or. It's killing my computer.
6 REPLIES 6
per.anders
650 Views, 6 Replies
Explorer must start when opening autocad or?
Mvh
Per-Anders
Pas
6 REPLIES 6
j.palmeL29YX
in reply to: per.anders
No.
You can start AutoCAD the same way as each other program.
What does kill your computer? And what means "killing my computer"?
If you want to get help, you should describe your problem more detailed and should ask what you want to know.
cadder
Jürgen Palme
per.anders
in reply to: j.palmeL29YX
google translate suggested it.
I mean that my computer gets really slow, dull.
Mvh
Per-Anders
Pas
DarrenP
what does that mean to the reset of us?
what is slow about your computer?
DarrenP
per.anders
in reply to: DarrenP
When you start Autocad, I suppose it will connect itself, as in my case, to explorer. to check the license. My question is, I can change Autocad's connection to, for example, Croome instead. Or I'm completely wrong.
Mvh
Per-Anders
Pas
j.palmeL29YX
Ahh, you are talking about the Internet Explorer (not the Win Explorer as I thought).
I can be wrong, but AFAIK AutoCAD needs urgently the Microsoft Internet Explorer. In the system reqirements you also can read that this explorer must be installed.
Of course it is not necessary to be connected permanently with the web. But after a time (I don't know how many days) Autocad needs a web connection to check your license.
cadder
Jürgen Palme
dgorsman
Mvh
Per-Anders
I would suggest your first language as well.  There is likely someone here who will understand and be able to translate better.
Note that your browser is irrelevant for establishing an internet connection to, say, the Autodesk license server.  These services use their own methods, not web browsers.
AutoCAD Inside the Factory
