Exploded 3D veiw of assembly drawing
alcohen
alcohen
I need to take a 3D drawing of a cabinet (for example) and explode the drawing so each part is moved from the center point of the object outwards.
This is allow the assembly crew to better see each separate part on the drawing.  I used to have an Acad addon called 3D burst which was PERFECT!  but the website is down and I can't locate it.
Thanks in advance!
Al
J.FOCHT
Try using the separate feature in solids editing, but thats unlikely to work.
  • Click the home tab
  • solids editing panel
  • solids editing drop down
  • separate command
Otherwise, there is no way to pull things apart like that in AutoCad. You would have to use an external editor for that.
See this post for additional comments by @cadffm and @MikeKovacik4928
https://forums.autodesk.com/t5/autocad-forum/disassemble-3d-objects-into-space/td-p/7545376
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
john.vellek
HI @alcohen,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Here is the website you mentioned. The program looks pretty slick. Thanks for the contribution!
John Vellek
cadffm
Untested: Try this App from App Store, Link inside: TNT
Sebastian
alcohen
Thanks so much for finding the website.  Unfortunately, that's the version I currently own.  I bought it years ago but it no longer works with current versions. Let alone that just today I am now using Acad 2018.  I am still going to try to install it and see what happens.  The contact email got bounced back when I asked for support.
So fingers crossed and thanks again!
Al Cohen
alcohen
TNT looks promising!  Thanks I will try in the morning!
john.vellek
Hi @alcohen,
Did the site from @cadffm prove useful? What is your impression?
John Vellek
