Excel Data Link Issue
I'm using Autocad 2014 and Microsoft office 2010 . I was able to insert the excel data link in the Autocad, but recently there is a problem with that and I see that it says: "The data link cannot be created because excel cannot be found "(attached message) .
I re-installed both Office and Autocad and both of them are 64 bit now .I don't know what else I can do to fix this problem.
Any help wold be appreciated .
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Try to start MS-Word, insert an Excel object in the same way and then double click this table in Word ... do you get then Excel started or do you get the same error-message?
Another trial with AutoCAD: what happens if you start Excel before you try to modify the linked table in AutoCAD?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Hi Alfred,
When I try to insert an excel chart in the word I have almost same error that excel is not installed !!!! but why??
Alfred.NESWADBA
That shows that this is not an issue with AutoCAD, something went wrong with your MS-Office installation. Or you have installed a cleaning tool going through your registry and cleaned to much.
If you have such a tool installed, remove it.
Login as admin, turn off antovirus software and re-run the MS-Office installation.
Good luck, - alfred -
Alfred NESWADBA
