Error when saving AutoCAD files
@Alfred.NESWADBA Well it seems that there is still some issues! 😕
Now when I save as this window pops-up and AutoCAD closes automatically
Edited by
Discussion_Admin
Alfred.NESWADBA
sorry to hear that.
When the error appears directly after the dialog opened ... how was the name "Senior 2 - Shortcut" selected?
Whenever I read "shortcut" I assume you have linked folders or files on the desktop? That should never be used to save files, please use the destination folder as shortcuts (especially to NAS drives) may fail in Windows.
If I'm wrong then please let us know
  • if that happens also with new files
  • if that happens when you save to your own documents folder
  • if the same happens when you first turn off antivirus software
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
Please attach a drawing so I can take a look for you. Please also give me some more detail on this issue if possible. I look forward to helping you resolve the error.
John Vellek
Hi
Problem was selecting the shortcut folder while saving... otherwise everything is working just fine... thank you for your consideration 😄
serkancavuslar
Hi
Files can give error.
He knows a trap outside our request.
Our precious files with drawings.
Power failure could be.
My advice;
Options / Files / AutoMatik Save File Location SAVEFILEPATH = D:\Autocad or C:\Autocad
Options / Open and Save = SAVEFIDELITY 0 and  LARGEOBJECTSUPPORT 1 and ISAVEPERCENT 0 and SAVETIME 4~6 and WSAUTOSAVE 0 and AutoMatic Save ON
These settings must be done.
and you must be comfortable.
Your file will be 100% safe.
Serkan ÇAVUŞLAR
Serkan ÇAVUŞLAR
CplCAD / Türkiye
