- Mute
- Permalink
- Report
Good Afternoon,
Background: I have 7 project .dwg files. Each with the same 440ish layers. Each with a large number of nested blocks. (15-17Mb file sizes)
Goal: Have 7 project .dwg files with 30-40 layers and minimal nested blocks to keep the file size down.
The reason the original files have so many layers is because they are exported from a fairly complex Revit file. The reason for the work is to conform the .dwg file closer to our companies standard layers and layouts.
A carefully went through the drawing and changed every line/text/block/etc to our standard working layers. I also went into each block (oh so many) and made the appropriate changes. I deleted a lot of the layers and purged the file of unused nested blocks. All is well.
Now I want to transfer my newly updated blocks to each of the other .dwg files. The best way I came up with on the forums was to have a "blank" .dwg with the newly updated blocks.
- Copy the model space information over from 1 dwg file
- copy the layouts from the dwg to the "Blank"
Now you should essentially have an exact duplicate of the dwg file, but with updated blocks.
The problem I am having is that when I go to use the Design Center or when I try and copy a layout over via "From Template" I get an error message. (error inserting layouts. operation terminated).
I tried this operation with another set of dwg files and it worked fine. So something in my project dwg's is causing the error. I was hoping someone had some insight into the issue. See attached .dwg files.
Thank you,
