Solved by acadhelp1. Go to Solution.
Try to ZIP the file and attach.
what type of file are you attaching ?
Could you more specific to the event when the error happens ?
Is it something when you tried to open the files ?
Something happened when AutoCAD starts ...etc
If you did create a new user account on the computer, you have essentially reset AutoCAD back to its defaults. You can do the same thing by using the "Reset Settings to Default" from the Windows Start menu.
