Error in angles displayed
When I use the command DIMANGULAR it creates the dimension with the correct angle but it shows the angle plus 10 in the command bar. Also when I use the command MEASUREGEOM (ANGLE) it shows the angle plus 170.
This only happend in this file. Anyone knows what might be the problem?
Alfred.NESWADBA
which setting do you have for angles in the _UNITS dialog?
+ can you upload that dwg-file?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
S.Faris
Is this how your UNITS look like? Type UNITS(enter)
Check the Units set inside the Dimension Style
SALMANUL FARIS
S.Faris
Step-1
Type ANGBASE(enter)
Change the Value to "0"
Step-2
Type ANGDIR(enter)
SALMANUL FARIS
Units and dimension style were correct.
ANGDIR and ANGBASE did the trick.
thank you so much.
