AutoCAD Forum
Error - Duplication and Recovery
1 REPLY 1
279 Views, 1 Reply
This has now happened twice so thought I should ask for some advise.
Today I had almost finished a Ground floor plan, simple lines, few furniture/door blocks and a bit of solid hatching.  There is a simple Xref inserted showing the structural grid but that is it.  I went to save the drawing and it popped up with a dialog box recommending recovery.  As I had nearly finished I thought I would just trim the last few lines then do this and when I trimmed a few lines and zoomed out it had duplicated all of my layers!?  When a selected by highlighting over the items left to right and unselecting 1 using shift there was 68 lines deleted(which were duplicates of a line within an xref), then I highlighted a table and chairs block and over 1500 were deleted.  This is not something i've done but believe it to be an error within 2015 or on my computer.  When I recovered the drawing some duplicates changed colour.
I've attached the file
1 REPLY 1
filipefrancisco
Duplicate post
see my answer in http://forums.autodesk.com/t5/autocad-2013-2014-2015/error-duplication-and-recovery/m-p/5483777#M710...
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
AutoCAD Inside the Factory
