Hi I was wondering if there was a solution to this or not?
I've also been getting the "Error: Device not found" message as well, but only when publishing using multiple sheets using an page setup override and using pdftodwg.pc3. It will print one page just fine using the sheet set manager override, or publishing using a page setup with the pc3 file. If I export to PDF I can do multiple sheets as well, but again it won't work with using the page-setup within the drawings or an override from the sheet set manager (preferred).
Also to note: this is only on Autodesk AutoCAD based 2016 products, because the .pc3 file we have on the server works for all of the other versions, so I know it's not corrupted as one troubleshooting solution suggested.
I also checked to see if the problem was with the .pc3 file created from an older version of CAD, but still had the same result with the one out of the box from AutoCAD & C3D 2016.
I've also taken a look at the page-setups being Layout, Extents, ect...as others have suggested, but no change. Makes sense considering I can still publish one sheet and it turns out great, but multiple sheets to no avail.
Someone also suggested in here that the file path to my documents under the publish options may have done it, but I'm still getting the same error message regardless of the original temp file location, my documents, and others.
Anyways, as annoying as this is I've been using 2015 for producing PDFs, I'm running out of things to try.
Any Help is much appreciated!
