Error code number 18015
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I never experience this issue before as I was trying to solid union the square beam and the message appeared below 'UNION
Select objects: 1 found
Select objects: 1 found, 2 total
Select objects: Specify opposite corner: 1 found, 3 total
Select objects:
The Boolean operation on solid and/or surface bodies failed.
Modeling Operation Error:
Error Code Number is 18015
So I tried to copy the cross beam like this 'X' in different locations and created a new beam and then it worked which is very odd. Originally I created the square beam by creating the square as a Region and then Extrude it to the long length. Any advice would be much appreciated! Thanks
