AutoCAD Forum
Error AUTOCAD for MAC
3 REPLIES 3
617 Views, 3 Replies
I’ve got a student version (AutoCAD for Mac 2013) , which I got from official website. There starting to appear few problems after a few months of my work.
1. when I’m doing a rectangle, lines that intersect or just lines that contact, in the point of connection appear small blue rectangles and windows of mistakes. If I trying to move only one element of this object, all others elements start to deform in chaotic way.
2. when I’m coping any object on the same page in one file, program start to buzz and I need to close the program despotic.
I’ll be really appreciate to get answer in Italian, because my English is not good enough or get contact phone of specialist to consult on phone in Italian.
Send a few screenshot.
Nadia
Milano
3 REPLIES 3
edwin.prakoso
I believe you activated CONSTRAINTINFER.
Try to deactivate it and see if it fix the problem. Below is from AutoCAD for Windows, find the similar icon in your AutoCAD.
Cheers,
Edwin Prakoso
maxim_k
Hi Nadia,
Yes, you have to turn off Infer Constraints: on Mac version you can find this button on Status Bar- first button to the right of "Model" word on your screenshot.
About " program start to buzz" - not sure what happens. Does it happens even in new, just created drawings? Do you use COPY command, or COPYCLIP (e.g. you use clipboard)?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
As additional tip: I can recommend you to remove Infer Constraints button from Status Bar:
- right click on Status Bar free space (not on on of the buttons) and remove check-mark from "Infer Constraints".
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
AutoCAD Inside the Factory
