eraze double solids
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear Community,
I am unable to remove duplicate solids neither with the ACAD CLEAN UP command nor with the file Doppelt.lsp, which I found in the web.
Simple drawing structure: I draw a rectangle and copy it so that two rectangles are next to each other. I extrude one of them into a cube. Now I select both objects and copy them again by choosing 0,0,0 as the base point and shift point. Selecting all objects confirms to me that there are now 4 objects in the drawing, i.e. two congruent rectangles and two congruent cubes. No matter which of the two cleaning methods mentioned above I use, only the double rectangle is removed, but not the double cube...? I work with AutoCAD 2015
Do you have any idea how to remove double solids from a drawing?
Thanks and kind regards,
Michael
