Equivalent of MAPTRIM in AUTOCAD or lisp
simon_bertinR5759
simon_bertinR5759
I'm trying to erase blocs outside a boundary in AutoCad. I know this command exist as MAPTRIM in AUTOCAP MAP 3D or CIVIL 3D.
Is there an equivalent solution in AUTOCAD ?  Ideally I would like to use it in a lisp code I'm wrintig.
Thank for your help,
JGAo1
Extrim in Express Tools?
JGA
pendean
Community Legend
Community Legend
Also look for an popular LISP in these forums called COOKIE CUTTER, and one called BREAKOBJECTS.
This TIP may be all you need ?
https://forums.autodesk.com/t5/autocad-lt-forum/extrim-alternative-in-lt/m-p/11690565#M198441
Side note: are you aware MAP3D is free to install and use for anyone with a paying/active AutoCAD subscription? That's another option to consider if you don't like EXTRIM command or those LISP.
jreidKVSUZ
Here is a lisp called DOUT.
Credit to:   CREATED BY / DATE: Daniel J. Squires, CADENCE May 92 p. 89
Do a right click onto the file once placed onto your computer.
It tells all about the file and what it does.
It maybe old, but still works great!!
Enjoy!!
JRR.
