Entity isn't planar
Entity isn't planar
neilyj666
Mentor Mentor
Message 1 of 24
Entity isn't planar
neilyj666
What does this mean (see screenshot) and how do I get around it??
Trying to convert the magenta object to feature line and the message appears - the object is a polyline and all Z values are zero.
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Replies (23)
Message 2 of 24
It sounds  to me like there's a UCS in play, instead of the WCS.  Somehow, your drawing got into a UCS that is tilted or shifted in the x or y axis, so the object that you're trying to convert is not in the same place (plane) as the WCS.
Check to make sure you are in the WCS and then list the object & see what it says.  You may need to either redraw the object, or try to block it out and then back in.
Reid
Message 3 of 24
neilyj666
A sample LISTing - don't know what bulge means put I assume it is what's causing the problem...
          at point  X=414607.580  Y=623921.493  Z=    0.000
          at point  X=414609.494  Y=623896.590  Z=    0.000
          at point  X=414521.476  Y=623889.781  Z=    0.000
             bulge    -0.420
            center  X=414523.170  Y=623867.847  Z=    0.000
            radius    22.000
       start angle    85.582
         end angle   354.376
          at point  X=414501.276  Y=623865.691  Z=    0.000
          at point  X=414501.414  Y=623864.291  Z=    0.000
          at point  X=414496.410  Y=623864.082  Z=    0.000
          at point  X=414490.387  Y=623925.252  Z=    0.000
          at point  X=414495.391  Y=623925.452  Z=    0.000
          at point  X=414496.473  Y=623914.466  Z=    0.000
             bulge    -0.408
            center  X=414518.367  Y=623916.622  Z=    0.000
            radius    22.000
       start angle   354.376
         end angle   265.582
          at point  X=414520.062  Y=623894.687  Z=    0.000
          at point  X=414549.289  Y=623896.954  Z=    0.000
             bulge    -0.414
Message 4 of 24
1st time I've seen bulge too.  Are you sure it's a 2d poly & not a 3d?  Are you sure you are in the World Coordinate System?  (UCSicon ON)?  I'm still thinking that the pline was drawn in an inadvertant USC.
Reid
Message 5 of 24
Jeff_M
The bulge in a pline is how arcs are defined, so this shouldn't be the issue.
Message 6 of 24
neilyj666
The original data was derived from a 3rd party but there i'm in world coords
Message 7 of 24
Try wblocking it out and then import the block back in.  Explode the block & see what it does then.
Reid
Message 8 of 24
Jeff_M
Also, what does the start of the LIST output show? Something like this:
LIST 1 found
                  LWPOLYLINE  Layer: "0"
                            Space: Model space
                   Handle = 12209
            Closed
    Constant width    0.0000
              area   16342.0114
         perimeter   502.2458
LIST 1 found
                  LWPOLYLINE  Layer: "0"                            Space: Model space                   Handle = 12209            Closed    Constant width    0.0000              area   16342.0114         perimeter   502.2458
or more like this:
                            Space: Model space
                   Handle = 12209
            Closed
Extrusion direction relative to UCS:
                   X=   0.9962  Y=   0.0000  Z=   0.0872
              area   16342.0114
         perimeter   502.2458
Message 9 of 24
Jeff,
The "extrusion direction"  does that give a polyline a "thickness" (z direction)? as opposed to "width".
Reid
Message 10 of 24
Jeff_M
No, that tells you that it is not in the current UCS, therefor not planar.
My guess here is that the "3rd party" this pline came from was Microstation. I've seen many cases where the MS created plines looked correct, but they have an extrusion of 0,0,-1 (normal WCS is 0,0,1).
Message 11 of 24
neilyj666
Thanks Jeff_M - I'll take a look at the LIST on Monday and repost.
Assuming this is what is happening is there an easy solution??
Message 12 of 24
jmayo-EE
Did you try exploding the pline and then use either MapClean or Join to recreate it?
John Mayo
Message 13 of 24
neilyj666
Jeff_M - you were right, there is an extrusion direction in the polyline
                  LWPOLYLINE  Layer: "Y-IHB-CH-RWE"
                            Space: Model space
                   Handle = a721
            Closed
                   X=    0.000  Y=    0.000  Z=   -1.000
              area   1397.315
         perimeter   221.102
          at point  X=414234.410  Y=623845.247  Z=    0.000
          at point  X=414253.739  Y=623822.228  Z=    0.000
          at point  X=414223.106  Y=623796.506  Z=    0.000
             bulge    -0.362
            center  X=414207.790  Y=623783.645  Z=    0.000
            radius    20.000
       start angle   139.980
Message 14 of 24
neilyj666
After exploding the polyline the original arcs seem to be the problem entities.
The Normal Z property = -1 and it is greyed out so I cannot edit it via the Properties panel - any ideas how I can get around this (hopefully avoiding recreating the arcs)
Message 16 of 24
neilyj666
Dwg attached - REVCLOUD around some of the problem entities - will look at the links later
Message 17 of 24
Jeff_M
OK, looks like this simple little lisp will fix this problem.
(defun c:normalize (/ ss idx obj)
  (vl-load-com)
  (if (setq ss (ssget "x" '((210 0 0 -1))))
    (progn
      (setq idx -1)
      (while (setq ent (ssname ss (setq idx (1+ idx))))
	(setq obj (vlax-ename->vla-object ent))
	(vlax-invoke-method obj 'transformby (vlax-tmatrix '((1.0 0.0 0.0 0.0)
				(0.0 1.0 0.0 0.0)
				(0.0 0.0 -1.0 0.0)
				(0.0 0.0 0.0 1.0))
  (princ)
Message 18 of 24
neilyj666
Thanks for the lisp code - now a basic question; how do I get it to run??
Message 19 of 24
Jeff_M
Create a text file, copy the code into it, save it as "normailze.lsp" to a place in your Autocad support path. In C3D, APPLOAD, find the file and load it. The command name is NORMALIZE. It's not fancy, so it won't report that it did anything, (unless it errors for some reason) but the 'bad' plines should now be 'good'.
Message 20 of 24
neilyj666
Thanks Jeff - I'll try it back in work tomorrow....
