Enhance attributs editor issue : changing the text style moves the attribut (shoudn't)
nesosimic98
Message 1 of 8
nesosimic98
I have this issue of moving attribut when changing text style. Shoudn't happen; the attribut have locked position (defined when ATTDEF was done)
Situation;
↑ Here above are the attributs in the drawing
↑ They are ATTDEF defined and in a block (note: changing text style in the block doesn't reflect int the drawing)
Tried methodes;
(1)
↑Back in the drawing, went trought Enhance Attribut Editor for the text style change
↑The result, a changed text style but self moving attribut... (note: this now doppped down position doesn't reflect in the block editor. There, everything looks the same as in the above block editor screenshot)
 ↑The same happens if a change the text style to the same text style. So juste changing the text style makes the attributs self moving.
Tried différent methods and none of them worked. Thid above on is my most concluent one.
In case it's relevant, here are the others tried. I'll post further screenshots of those one if needed.
(2) Changing the text style in the block it self (check above) - the change dosn't reflect in the drawing
(3) Changing the text style of the attribut on it's own (in ths case Surf.) trought BATTMAN. Nothing changes...
Thanks for your help 🙂 @all
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
We'll need access to your block, share that in a container DWG file here please: in the meantime it appears you're not taking into account the text/attribute insertion point when changing sizes from 15 to 10 maybe.
Message 3 of 8
nesosimic98
Here the attached .DWG
Regarding text's hight, it's just a selecion mistahe from my side amde during the screenshooting. The 15 the 'Loggia'' text seleted. and 10 for the square meter one (the actual text I want to change text style. I confirmed it stayed 10 all allong.
Message 4 of 8
imadHabash
Thanks for the CAD dwg file...
as much as i understand that the text will move from its origin space if you change the style.. If so, Click on below image to see how from BATTMAN command you won't face that.          Ami right?
Imad Habash
Message 5 of 8
nesosimic98
Thanks man,
Wow that's strang. Do you know why it hasn't behaved like that before ? As you can see when you open the Text style from BATTMAN, I already made it as Arial Bold, But nothing haooened then (Yes the modification were approved)
Any idea ?
Message 6 of 8
imadHabash
Honestly NO , i don't have any idea!!!
All what i know that it behaves normally when i change text style from BATTMAN command.
Imad Habash
Message 7 of 8
nesosimic98
Then we will never know
Thanks for your help @imadHabash  and @pendean
Wish you the best from Switzerland !
Message 8 of 8
imadHabash
@nesosimic98
All the best for you ...
Imad Habash
