AutoCAD Forum
Engrave
1 REPLY 1
321 Views, 1 Reply
Engrave
Anyone know if there is a way to engrave a psd, pdf, or jpeg onto an autocad 3d object? Thanks in advance!
1 REPLY 1
pendean
I take it you want the content of those files to be engraved, and not the actual rectangle that makes up the static image? If so, then no, you need those shapes as AutoCAD objects you can subtract from the face.
If I misunderstood then please post a JPEG you want to use and explain what this 3d object is in more detail.
AutoCAD Inside the Factory
