Either SCALE a solid on a single axis or UNION a 3D block with a solid.
05:23 AM
- Mute
- Permalink
- Report
I'm trying to SCALE a solid on the Z-axis only and UNION it with another solid.
The problem is that SCALE only works on XYZ and if I convert the solid to a block using the BLOCK command and scale it by altering the "scale Z" parameter, it will no longer EXPLODE or BURST back into a solid.
You also can't UNION a block with a solid even if the block was made from a 3D solid.
Is there anything I can do? Are there any add-ons that will scale on a single axis?
