edittablecell automatically appear when changing anything on table
jung_kim
Observer Observer
jung_kim
Observer
Observer
I went from AutoCAD 2015 to 2019 recently.
I use Sheet Set Manager to create the list of drawings.
After the create and place the list of drawings on a paper space, whenever I try to change anything on the table (for example, assign Header cell style to a subset. or press "download from source" button) EDITTABLECELL command activates at the bottom. I have to press Q for quit every single time I change anything to the table.
Is there way to disable EDITTABLECELL command from appearing?
natasha.l
Hello @jung_kim
You are not typing the EDITTABLECELL command to edit the cell? Try not to use the command, instead click a cell wall then choose the cell.
If you are not using the command, please share your file with us so we can take a look.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
jung_kim
Observer
Observer
I am not using the Edittablecell command.
Problem with choosing the wall is that it selects the whole table.
Sometimes I need to choose  a cell and change the cell style from "By Row/Column" to "Header"
Edittablecell command automatically triggers when i make a change to a cell.
Which forces me to press q for quit before selecting another cell to make changes to that.
I know it seems like a very small thing. "oh no you have to press q after making a change to a cell" but if I have to make changes to many cells, it starts to get annoying.
natasha.l
Hello @jung_kim
It's sounds like some strange behavior to me, you should be able to create a table & select a single cell without the edittablecell command popping up. Try testing this on a brand new file if you'd like.
If you discover that its isolated only to this file & table, then you found the root cause. We have had other customers report strange issues like this & it requires Cleaning Up the AutoCAD Drawing.
normeo.2016
@jung_kim Google translation added by community manager @lena.talkhina :
The same problem appeared on ACE 2021 after installing Raster Design. Incredibly‌ annoying
The original message in Russian:
Такая же проблема появилась на ACE 2021 после установки Raster Design. Бесит невероятно😡
Casey.Clark7VTME
Have you figured this out? I have to fix this every time they give me a new virtual desktop or upgrade the program but I can't seem to find the solution on Google anymore. Guess I should've bookmarked it when I had the chance.
